joshhemming
- August 15, 2011
- El Paso
- 93 Aerostar 2wd 3.0L
My 93 2wd Aerostar's rear axle does not have a drain plug, so I have to loosen the housing bolts and drain it the messy way.
The Haynes manual says after draining and cleaning, to put a thin layer of RTV sealant on the housing and install a new gasket. But the repair guide at Autozone's web page says just use a continuous bead of the sealant, and no gasket. Which is correct? I'm thinking the last time I did this I only used the blue sealant and no gasket, but it was 10 years ago and I'm not sure.
Also, I'm not sure about the oil to use. The Haynes manual says use Hypoid oil, and gives a Ford spec. It doesn't give an acual weight. I have an unopened bottle of Quaker State 80-90 GL-5 High Performance gear lube oil which says on the label "provides extreme pressure protection for hypoid gears". Would this be suitable for my diff?
