SkanlaxJMO
- September 30, 2005
- Syracuse, New York
- 96 XLT
maby try airing up the tires or smaller rims and not lo-pro
SkanlaxJMO said:maby try airing up the tires or smaller rims and not lo-pro
SkanlaxJMO said:maby the floor mat is in the way of the pedal
Ford_Racing_Guy said:I don't know if this will be compatible with the explorers but being the same Transmission you may wanna look into this.
Called the Jerry's Tranmission MOD (modifications to the 4R70W valve body) i've considered doing it to my car to firm up my shifts and get a nice chirp into second.
http://www.tccoa.com/articles/tranny/index.html#
maybe you can use it.
rocket 5979 said:The J-mod is for the 4R70W trannies. The tranny we have in the 02+'s is the 5R55W which is very different. The 96-01 V8's have the 4R70W tranny though, in which case this mod would work. Or a person could just go out and buy a Baumann shift kit for only $100.
Coach_Al, the best way to get our trannies to shift faster is to increase the line pressure and shift rpm. For off the line power your tuner will need to add more spark timing and lean out the fuel mixture just a tad. Try datalogging with your current tune's spark timing tables and send me the log. I will compare it to some others I have around here and see what the difference is.
Oh, BTW just FYI all 02+ Explorer V8's have the 3.73 LS rear end and the higher class towing package too.
coach_al said:Thanks... Can't datalog yet. I found out that the problem with the X2 is the latest datalogging software has been pulled from the website. They found a bug and are fixing it. You may want to check out the SCTFLASH.com website if you have version 2.3.4 of LIVE LINK.. Here is the response I got from SCT
In order to datalog on the device itself, you will need Livelink ver 2.3.4. If yours is older than that, you will need an update. This has been temporarily removed from the downloads section because of a few minor bugs, but it will be fixed soon and back in the downloads section. You will also need an XC2 with firmware of 1.9 or 1.10. We will have an update for older firmware soon also.
James
SkanlaxJMO said:yeah the L/S is probably hurting you.
