OK, I'm in the final planning stages before I put this bad-arse 302 together. I'm got allmost all my stuff. Gaskets and valve springs are a stop at Jegs on teh way home from being mine.
That leaves one final peice to the puzzle. The hardware. I just ordered stainless steel allen head bolts for my headers, oil pan, thermostat neck and valve covers. The Intake manifold bolts and timing cover/water pump bolts are grade 8. 4 of the 12 intake bolts are studs. 5 of the 9 water pump bolts are studs as well as some of the lower timing cover bolts (IIRC.)
So my question is, where can I get these studs? Do I need to make them from all-thread? Can you even buy grade 8 all-thread? I think if I can find it I can make it work. I'm sure it's not a best practice but a stud isn't much more than all-thread with a nut welded in the middle of it anyway, correct?
Thoughts? Ideas? Alternatives?
