You will need new rims for the backspacing. You will need to recalibrate the speedometer as well. I think everything will be off like 3-5 miles an hour less than what your really going.
If you're getting new rims you should get 15x8 with 3.75" BS. The stockers will work, but you'll rub on your front swaybar and possibly also on the firewall.
Every Explorer is different in terms of exactly what they'll fit. You may end up needing a 2" body lift or more suspension lift to make 32s work well.
Correct...With TT/Shackles you should get about that. If you dont mind some trimming go for it. Every X is different so you may not have much, never know till you try it.
thanks guys. im gonna go with the 31x10.50 with the black rockcrawlers? 15x8 right? do i need any backspacing on these wheels? 4wheel has this package priced at $495 i think.
