Will a 5R55E fit in a 2004 Explorer 4.0 4x4 currently with a 5R55S? | Ford Explorer - Ford Ranger Forums - Serious Explorations
Amarotica
2004 Explorer
My 5R55S is destroyed with multiple issues and the 5R55E is a few hundred dollars less for a remanufactured unit with sleeved servo bores and all the important valve body upgrades and such. Does anyone know if it will bolt up the same to the 4.0 engine and transfer case as the 5R55S does? I've read its identical except for the gear ratios but will the electronics and bolts all match up also? Thanks in advance!
Curious to know what kind of quotes for reman trannys you got which reman companies you looked at. Thanks.
