Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
Yomie....3/4 ton build up and install
- Thread starter Yomie
- Start date
Add an avatar, upload photo attachments, and more!.
Yomie
- November 29, 2000
- Biloxi, MS
- 06 Toyota
I think its perfect where it is -- if anything, I'd move the rear axle back an inch or something. But thats no big deal.
I moved my rear axle back like you did IZ, but wish i could go a little more, i'm thinking about using the chevy 63" springs and moving the rear back another 5", i don't know yet, i'm gonna try it the way it is
As far as the front goes, i think i will leave the axle placed where it is at now and try it out, if i feel i need a little more, then i will flip the springs and move it forward
So i'm now planning to be at a 105.5" Wheelbase
Yomie
- November 29, 2000
- Biloxi, MS
- 06 Toyota
Time to get some wheels with less backspacing too.
lol, you don't like it
I plan on ordering up some double beadlocks
Yomie
- November 29, 2000
- Biloxi, MS
- 06 Toyota
Well did a little work today, its not 100% done
I still need to bypass ABS controller, redo shock mounts front and rear, install hydro-assist
out with the old
out with the old
Yomie
- November 29, 2000
- Biloxi, MS
- 06 Toyota
lol, 7 hours straight today, basically just swapping axles today and making steering
Got it up to about 50mph today and drive excellent with unbalanced tires and no rear shocks
The rear axle wraps up pretty bad just cruising, so an axle wrap bar is in order
Yomie
- November 29, 2000
- Biloxi, MS
- 06 Toyota
I did some research and my stock brake master cylinder has a 1.125" bore, which is enough to run these large brakes (stock '78 F-250 is only 1" bore). I still have the lines going through the ABS pump and i can still lock up all 4 tires at 30mph, the pedal is jsut a little soft, i believe i have air in the abs pump, so hopefully in the next week i plan on bypassing the ABS pump and see how they do, i have not yet installed the proportioning valve (not needed right now) but we will see when the ABS pump is removed
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
- 1998 Ford Explorer
I know it sounds weird but the smaller the bore, the more pressure you're going to apply onto the brakes which means better gripping power when you're just about to crest a drop ("pucker" moment!).I did some research and my stock brake master cylinder has a 1.125" bore, which is enough to run these large brakes (stock '78 F-250 is only 1" bore).
A fundamental of hydraulics:
Pressure = Force / Area
With a constant Force coming from your foot and to brake lever/pedal (assisted by the booster), you can kinda see that dividing the Force by a smaller Area will result in larger Pressure. Smaller area of course means smaller bore.
So what you might want to do is switch over to the smaller 1.00" bore or maybe even 7/8" -- I know the 7/8" exists cauz some off-roaders use em.
Of course theres no such thing as a free meal so the downside of this is that the brake pedal has to move just a little bit more in order to move the same amount of brake fluid to fill the cylinders in the calipers.
Yomie
- November 29, 2000
- Biloxi, MS
- 06 Toyota
Yeah i know, i read alot of the wars on pirate, everyone on there says move to a 1.25" bore, which i don't like...I'm definitely not going any larger in bore size. I wan't to see how they do without the abs pump first before i make any decisions, but they actually feel pretty good right now. Once i get the pump out, i'm gong to test the holding capacity in a ditch or something.
- February 11, 2001
- Red Bluff, Ca
- 1975 Ford Bronco 4x4
Whats your plan for the ABS? I'd like to remove mine in the next year or so.
Yomie
- November 29, 2000
- Biloxi, MS
- 06 Toyota
I"m going to run the front port (on the M/C) straight to the rear line, and the rear (firewall) port to a t-split and to both the fronts.
For some reason i don't think that waht your talking about, if that not the answer you were looking for please elaborate
I thought you already removed your ABS
Since i have a '97 i do not need any part of my abs pump system for anything, and i got tired of looking at the ABS light on the dash a few years ago, so i went ahead and pulled the bulb out
- February 11, 2001
- Red Bluff, Ca
No.. thats what I was talking about. I haven't removed the ABS module yet. I need to though so I can get some new shock hoops made and in place. I'm just waiting for a 'brake line flaring how-to' to show up.
IZ and I found a so-called Explorer M/C with a built-in proportioning valve I'm gonna try out.
Yomie
- November 29, 2000
- Biloxi, MS
- 06 Toyota
Brake line flaring...ugh yeah, I know at napa you can buy sections of line with ends already on them, i am probably gonna go that route. With my rear axle i bought a section that is 40" long and another that is 20" long.....makes it so much easier
With the brake lines i will unmount them from the ABS module and just use a t-fitting for the fronts and the rear where i disconnect them i will probably put in the prop valve, makes it so i don't have to flare lines. It may not be the 'cleanest' way, but then i don't have to worry about leaky flares. I tried flaring lines when i did my first sas and it didn't turn out pretty, i'm not a good flarer, lol
- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
How about an F-250 hydraulic booster setup
Looks nice, you have tire coverage laws in your area? LOL
- October 20, 2004
- Pulaski, TN
- 1991 Explorer/2002 F-250
This is exactly what i did with mine. Its very easy this way
Looks awesome and you are a very fast worker
034x4
- January 16, 2005
- B'ham
- 2003 Ranger Edge
How about 4 of them?
Looks good btw. now paint it odg
Edit: When you puttin the blocks in? or you just haven't trimmed the u-botls yet?
