It is entirely in the exhaust system, nothing upstream of the headers. You can swap any Explorer 302 into any Mustang and it will sound absolutely the same as the Mustang 302. The slightest difference in the Explorer GT40 lower intake and camshaft has no affect on sound.
Thus work on the exhaust, the mufflers are 80% of the sound. You have little choice for headers, and nobody makes non stock cat pipes. Make your own cat pipes with high flow units, and add a decent crossover before two mufflers, and twin tail pipes. Good luck,
Idk i have to disagree somewhat. Lets compare both accurately...
I've heard several 99 5.0 Mountaineer's with no cats and 40 series flowmasters. I've also heard many fox and 94 5.0 mustangs with no cats and 40 series flowmasters(both true duals). Same exhaust but they sound different..
The mustang has such a throaty "built motor" sound when revving and accelerating. They also sound like they rev very quickly.
On the other hand, the explorers i've heard sound pretty good, but not the like mustangs. The explorer, with comparable exhaust to the stang, sounds like it is still "muffled" to a certain extent.
Thus bringing my conclusion that (i would like to think) Ford tunes the mustangs "hotter" than a normal 5.0 explorer, making the exhaust/engine note considerably better. My goal is to find out HOW to get a 5.0 explorer motor to sound like that..
What do you guys think?
Stop and go back to my last two posts. All of the answers are in there.
To repeat myself with different words, you cannot compare the Explorer and Mustang directly as long as the Explorer has the awful headers on it. I mentioned that, and you casually ignored that fact. The engines(long block) can be swapped and they will sound exactly like the vehicle did before. The headers can not be swapped between the two, that's the one thing which will determine the biggest difference.
Like I said, reconstruct the Explorer exhaust with similar cat pipes, cross overs, twin mufflers, and two tail pipes, then they will be as close as possible. I mentioned all of this before, it is entirely about the exhaust, and you are stuck with the small headers. Good luck,
Jon, we spend too much time trying to explain these basics to younger enthusiasts. Too many of them think that the sound is connected to performance. They figure if they can match the sound that magically they can start racing Mustangs?
FYI, I noticed in a Jeg's catalog today that Rhoads makes an OEM replacement roller lifter. I loved the Rhoads lifters in my old 351-4V Gran Torino, it helped the low end torque a lot. I may buy those to work with the 212/222 cam that I plan to use. The stock cam is not much over 204 degrees, and the Explorer's strength is from 0-20mph. I don't want to lose any of that. Regards,
