You are correct, the steering rack and shaft are v8 specific. The v6 parts will not work. I used aviator exhaust manifolds. The exhaust ports are different from sohc to dohc. The factory explorer v8 exhaust bolted right up to the aviator manifolds. As far as the chassis, any 3rd gen will work. The engine mounts are even the same form v6 to v8. There is a seperate adapter plate that goes from mount to engine that is specific. For the most part, all 4.6 blocks are the same. The explorers used an aluminum block as did the Cobras and mark viii. Also aviator and some expeditions. The 4th gen explorers switched back to iron blocks when they went to the 3 valve heads. I think the 2nd gen explorers are a little too small also. If you wanted to go that route I would look for a 302 or 351w based swap since they already had 302 in them. If you find a 3rd gen v8, a dohc will drop right in with only the exhaust manifolds and wiring harness changes. I would have just done that, but the '03 donor that I bought had some pretty bad rust on the pass rear, which mine has none. There is plenty of room for a roots blower on top. I would probably go with a turbo setup since my engine has the twin port "B" heads. I am having trouble finding an affordable intake to fit my heads and mount a blower. The single port heads have factory parts for that since the 03 and 04 Cobras have that engine. If you do this swap, get an engine with "C" heads. Basically 2000ish engines are all this setup. I would suggest finding an aviator engine. Or a wrecked aviator. Take the engine, both engine harnesses and all the accessories. The radiator setup is different on the aviator also. And they have an additional electric cooling fan. Lots of little things. Plus the brakes are a nice upgrade.
