- August 27, 2001
- Location
- Down by da river, hon
- North East, MD
- '95 Sport
All right all you gearheads and engine swappers, this is a very serious question that directly concerns the future life of my '98 Sport. I've been bandied about by just about everybody on what type of engine I should be swapping into Blackjack... Lemmie just say that while streetability is a major concern, having the most powerful engine that I can cram in there (without modifying framerails!) is the bigger concern This is a lowered truck btw, no body lift
I started out wanting a 347 so that someday I might be able to challenge the mighty Troll. But all I keep hearing is how 347's have such bad oil delivery problems and how the wrist arms cause premature cylinder wear. Theoretically a 331 would put out almost the same power and cause a lot less damage in the long run, but I'm having a hard time stepping down from that advertised 450 hp of the 347 Some coworkers have suggested using a fuel injected 351 and stroking it out instead, since dimensionally it's pretty much the same as a 302 block. But then there's problems with cramming an AOD trans in there...
This'll be a professionally built engine no matter what I decide on, but I'd like to keep the potential issues with wiring and trans choice/fitment to a minimum as I DO have a budget NEED OPINIONS HERE!!!!
