cknorw
- August 17, 2006
- Hiram, GA
- 99 Crown and 03 Explorer
I looked through the forum and found similar info, but symptoms don't quite match mine. For give me if duplication.
I have a 2003 Explorer XLT, 4.0v6, 196,200 miles. Original Transmission. The vehicle was a company car driven primarily on the freeway for its first 166,600 miles. My wife drives it now so I don't have a good feel of any symptoms leading up to its current problem. Finally had a chance to drive it today. Hope description makes sense....
First gear seems to engage and hold well. Second gear won't engage until you got off the throttle. If you stay in throttle (just normal driving), the RPM will reach/exceed 3000. I didn't push the issue, always got off the throttle and would immediately engage second. Once second engages, third and forth seem good. Will not engage overdrive. Before, final drive speed at say 55, rpm below 2000, now at or above. If going at very low speed, seems like shifting to neutral and then will not engage second. You have to slow enough to go back to first. The issue is accompanied by flashing O/D. If you drive with O/D off, no flashing O/D. If O/D on, O/D starts flashing once you come up to speed. Triggered CEL this morning... P0775. CEL did not trigger with initial occurance. Had fluid checked, not changed, 6000 miles ago. No evidence of leak under vehicle; completely dry! Obviously, no dipstick to check level. Have not crawled under to check yet. Will do today! (It takes a dipstick to design a tranny without a dipstick!) Looking for ideas!
This forum was extremely helpful four years ago, helped me rebuild my 4r70W in my 99 Crown Vic. Crown still going strong, with just about 60k on the tranny. Thanks
