The Breeze
- May 17, 2011
- Santa Clarita
- 04 Sport Trac XLS
I am getting ready to add a leaf to my sport trac which already has the warrior shackles so I needed longer sway bar links. Then while I was at it I decided to make them easy to take off when I go offroading. It only takes a few hours and $6.
All you need is 2 clips, a 10" black steel pipe with 1/2" inside diameter.
Once you have the sway bar links off you will have to cut off one end or the other. It doesnt really matter which side it is. Cut about an inch up from the weld on the side you choose.
Take the steel pipe and cut the threads off. You can use a sawzall but a pipe cutter leaves a much nicer cut. After the threads are off, the pipe will be about 8" so cut that in half.
Take the longer side of the sway bar link and slip it in until the pipe reaches the bend in the link. Now you can tack the pip so it doesnt move or just hold it still but you need to drill a hole through the pipe and link to slip the clip through.
Once that is done all you need to do is weld the connection that was cut off to the other side of the steel pipe. Just make sure that when you drill the hole and weld the other side that you make the clip easy to access and the links line up. When I drilled the hole I made it run the same way as the bolt hole in the link. When I welded the top I put the Link back in the truck and tacked it so I knew it would all line up.
Now just grind it up and paint it all. Thats about it. If you have any questions let me know. Its pretty simple. You should end up with something like this.
