I know this has been beating over the head bit can anybody ruffly tell me factory height from ground to the bottom of the fenders on a 4wd? I have 04 adrenaline with 285/75/16 and im trying to figure out were to start as far as doing the tt/add a leaf and eventually doing a bl.
Hello I want to lift my sport trac to get some clearance but don't want anything crazy maybe 31s under it...what's the best lift option?
Put the tires on. Twist the torsion bolts until you're at the desired height. Get an alignment.
At best, you're gaining .5" clearance if you currently have the larger stock 255/70R16 tires. If clearance is truly your goal and not looks, you may be disappointed. That's roughly the size of your thumbnail. Curbs won't even become easier.
Sent from my Galaxy S5 using Forum Runner
Yep, if you have the 255/70/16 = 30x10x16, you can go up to a 265/70/16 = roughly 31x10.5x16 with no lift needed.
So what would you recommend as far as lifts instead of a TT
Can some one tell me everything they know about body lifts and how it will look,and if my tow hitch will still look okay thanks
Thanks for the info...tried to post pics but don't know how on this forum34" front and 36" rear. Stock on 255/75/16
