1992 explorer gets a solid axle and v8 5 speed | Page 6 | Ford Explorer Forums
Gates water pump
I was able to source water pump / timing cover bolts from another engine in the shop. This is a great way to store 5.0 waterpump
Bolts
Each bolt was cleaned with drill and wire wheel
New gasket sandwiched w permatex copper
Ford calls for thread sealant on the bolts that go through waterpump, through the timing cover and into the engines water jacket. Many 5 oh dudes will also use silicon here… but i still do fords way with the thread sealant
Surfaces prepped scraped, wiped w alcohol prior to gasket install
Next the heads and head gaskets
Engine tech Head gaskets and new head bolts
Heads were wire brushed to remove loose dirt, then old gaskets scraped, then cleaned with air, then cleaned in parts washer, finally drip dried
Heads gasket surfaces final prepped with 3m rotary pads, wiped with alcohol, and then finally the gasket and head installed on its dowels
New felpro torque to yield bolts dipped in oil and installed finger tight
Continue the head install
Heads old gasket material scraped with razor blade
Then surfaces prepped with 3m roto tool
Blown off, wiped clean
Visit to the parts washer
New Enginetech gaskets
Good shot of gasket installed
Next side
Final torque
Always check Gasket orientation on block
Before grabbing head i like to have two bolts prepped. Oil on the threads and under the bolt head. Gasket set and ready
I have torque values posted on the wall because i do this often
Also the hilarious harbor freight 10mm missing set
First all 20
Bolts torqued to 30 ft lbs
I love this icon dial type torque wrench
Then to 45
Then finally to 55
And now switch to 1/2” drive and long bar, ready for the 90 degree final turn. This is what stretches the torque to yield bolts
Both heads on and final torqued
She was Ready for next round of parts
I found a good remanufacture of the oem cam synchronizers, I don’t trust the aftermarket parts much anymore so we are getting to the point where reman is better option
This is a 3 wire 96-97.5 style synchro and sensor
The valve springs still needed to be compressed so I can replace the valve stem seals, valve springs, cups and retainers with the new comp cam digs
I picked a new valve spring compressor that made this job sooooo much easier
Valvetrain time!
Had to make a fixture for the valve spring compressor
I also have been wanting one of these… got a new tool for the shop
I love this little box new lifters come in
These are the stock lifters from this engine
Been in storage
Traditionally I take all 16 apart one by one and inspect and clean them
It can take some time! There is the grime from one lifter cleaned w alcohol picks and q tips
Used this as an excuse to get a new tool
I cleaned one and said screw this I’m getting it. 6liter harbor freight sonic cleaner. Filled w 2/3purple power 1/3 water
Lifters are in pre wash now … I will take them all apart, clean them in this bad boy, and then assemble. Will save so much time
I clean enough small parts to put one of these to work. I even gave it a dedicated shelf
Two bolts were welded together to make a screw in fixture for new valve spring compressor … another major time saver
My dad always said two things:
“There is one way to do a job”
And
“Use the right tool for the job”
Ratrod at harbor freight
Oooh la la sbf
Dang need to rotate these pics
Back from pre rinse a 15 minute cycle look good! Made it easier to take them apart, loosened up all the sticky grime inside
Now to clean the individual parts and hollow cores in batches of 4, using a jar to contain the small bits
No way could I get them this clean without spending all day.. now the cleaning happens mostly while I work!
Little assembly line going on
4 Lifters being wiped down, assembled with clean oil while 4 more are in pieces and cooking in the sonic washer …next 4 being taken apart after pre rinse. In one hour +/- I had 16 clean and lubed fresh lifters
@410Fortune Your dad's wise words have been added to my list of memorable quotes. Your dad raised a smart guy.
I dig that 10 mill set, I guess somebody finally had enough!
I figure the only way to get Josh to quit pushing the 351 on us is to build one!!
I would Love to build a sport trax with a bored over 351 based small block ;)
Then he will be coming in here saying what?… “ 460 time!!! “
Trying to get me to big block a poor little ranger lol lol
Holy smokes that’s just what a tiger needs is a big block? The 302 was plenty in that car hahahaha
Any pics? Hahahahahaha I have a 472 in my plow truck… what a beast!!!
351W based 460 stroker. Ford Motorsports sells a short block.
Well, we were 17. We had a Tiger with a blown engine and a 460 on a stand. What other possible outcome could there be?
We did get it running, but it wasn't pretty. Friend's Dad sent it off to his car builder after he found out what we did to his Tiger. He was a collector and had a metal building full of future projects that we helped ourselves to. I don't remember him being too pleased with us, but he wasn't that upset either. I know it eventually got finished, but that was years later and I was into dirt bikes, Baja Bugs and my 396 SS El Camino by then.
I love the 302/5.0; I put 75,000 miles on my old Fairlane, 15k or so on the first motor, burning a quart every 200 or so, plus (I later discovered) cracked piston skirts and one that actually broke off. And I'm pretty sure I remember when it happened, although I drove it another year before the "new" 302 went in. I might be a little late, but one thing I like to do on these is coat the upper half of the timing chain cover bolts with anti-sieze. It's probably not as important if you've got quality coated bolts, but one problem you ran into working on the old ones was the bolts would seize to the timing cover.
