demaris
- July 17, 2014
- reno, nv
- 1993 sport explorer
so, i have the 93 sport that was built too close to calif. has the cam sensor at the rear of the block. throwing intermittent codes that indicate that the sensor is sending incorrect info (away from the car at the moment so can’t give you the code). my question; can this sensor be disconnected and a pcm from 93 exp that didn’t have the sensor be swapped in? in nevada, need smog test because i went over the 5k mile limit for a classic car by 100 miles. won’t make that mistake again. sensor is a bxxxxxxch to remove and even worse to replace not to mention the cost. anyone have any experience with this? btw, this sensor is specific to the 93, maybe the 92 but not the 94. 94 sensor is easier to r&r and cheaper also.
