justinkt45
- May 19, 2009
- Iola, KS
- 1994 4x4
Noises problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic 161 miles
I bought a 1994 Ford explorer for 500 and the body is in good shape but needs alot of repairs.......
1. When going down the road the tires make a loud humming noise when i get up to speed but when i turn a tight left it will stop! The mechanic said i need new upper and lower ball joints and maybe new camber adjuster sleeves. Is he right? I need a pros help!
2. Second of all my low oil pressure gauge always stays low... so am i in need of a new oil pump or oil switch?
3. Third of all when i stop at a sign or light you can hear a small thump. Is that the transmission? If so could i drain it and re fill it and it will be ok? Or is it a sign of it going out like a down shift problem.
So basically im asking the experts if this vehicle is worth fixing... is the engine to bad to be fixed?
