brownskee
- November 21, 2023
- snohomish, washington
- 1995 explorer XLT manual
I will start this off with I have been searching every where with this issue and no one seems to have the same problem. This one has been manual swapped by the previous owner with the stock ecu and gem so it has every transmission code there can be which I cannot figure out if it has any relation to my issue or not. The real problem is I am driving and it will act like it's sputtering and heavily down on power like the flip of a switch, and usually last about 10 seconds and then goes back to normal, sometimes it lasts a second or 2 and then goes back to normal. If I turn the ignition off and back on the full power is back. This repeats every couple minutes. If anyone has had a similar issue on an OBD1 rig or even an OBD2 I would really appreciate any advice on this as I don't really want to just throw parts at it. It only has 141k miles. Thank you in advance.
