- July 28, 2012
- North Ga
- 05 F250 6.0
Servos covers can be tough to get out on other transmissions too, one thing you can try is to use a sharp flat screw driver and hammer on the cover and work it back and forth. Now this is easy on covers that have a area that you can get a groove or flat surface to hit on, but on this particular cover it is smooth and does not have a spot to hit against.
With a file you may be able to create a groove on the smooth machined area around the cover on two sides enough to get the screw driver to hang on. You may be able to work it out like that.
I have never done this with this transmission because at this point the transmission is usually on my table and I can drive them out from the inside once it apart.
Try this first before ripping back into the pan maybe you will get lucky.
