97Sandbox
- February 7, 2019
- Seward, NE
- 2000 Explorer Sport
I had another thought today:
When I was installing the shift kit, I had a heck of a time getting the forward modulator valve (or maybe it was the forward engagement control valve, I can't quite remember) out. I got it eventually, and swapped out the spring per the Superior instructions.
What I'm thinking though, is if any given valve is bent or forms a burr on one of its outer diameter edges, it will likely hang up in its bore and not actuate fully. Could it be that the 3-4 shift valve in front of SS3 is damaged and is hanging up in the VB and causing my P0761 code?
I'm just speculating here, but intuitively, it seems reasonable that the shock of my "double down shift" could have damaged a valve. Is there a specific valve in the 5R55E that's prone to this kind of malfunction? Better yet, one that would have something to do with SS3 not engaging!
I have a bunch of spare valves that I pulled out of the VB I took the blow off valve and updated separator plate from. When I get my VB out, I may try to pull every valve I possibly can and swap any valves that look suspicious.
Let me know if this is a good plan or if wishful thinking is getting to me again!
