so im curious, do you thinks a 2001-2005 or newer front bumper will bolt onto the 95-2001 explorer frame horns & are those stock explorer flares on the back or are they Ranger flares, they tend to look different?
So do you have any modification pics to what you did to make the rear flares work on the explorerThe fender flares all came over from the Ranger. I had to cut them in to fit the rear.
I just held the flairs where I wanted them, marked a few holes for the fender clips, drilled them, installed the fender with enough clips to hold it in place, then marked the rest of the holes and used a scribe, dragging it along the fender to mark what needed to be cut-off for better fitment. I was able to use a utility knife to trim them to fit. They don't fit perfect so I used a little black caulking.So do you have any modification pics to what you did to make the rear flares work on the explorer
Both you Blown and BoominXplorer on this thread and the picture of the Sport Trac with the "power dome" Ranger hood (below) have inspired me to try and fit a 2003 "power dome" Ranger hood onto my 2003 Explorer Sport. My present hood is all dinged up from bombardment of falling acorns last fall so it needs repairing. I found a power dome hood for less than $100, so I have nothing much to lose. Props on the body line / stripe deal, way to tie it in without spending hours of sheet metal fab.
Looking good Blown!
ditto.
I was thinking a set of the wider and streamline mountaineer door moldings would look good too.
