Note: This feature currently requires accessing the site using the built-in Safari browser.
Performance Upgrades - Maintenance - Modifications - Problem Solving. Covering the Explorer, ST, Lincoln Aviator, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Aerostar.
My right headlight doesn't work. Have replaced bulb, swapped left to right still no right headlight. Checked fuses-ok. No power at bulb socket. I don't see a headlight relay in owners manual. I would think it has a relay? What y'all say?
I had no power at headlight bulb plug. Checked fuses,headlight switch,turn signal switch & wiring. All ok. Got a wiring diagram from online for free at autozone found after fuse power went into smart junction box also known as body control module.come out of SJB on circuit c2280e pins 20 & 30. No power on pins 20 & 30. I have a bad SJB cost $270.00 from ford. Part number 6L2Z-15604-CA. Hope this will help other sports trac owners.
