tvarghese
- September 30, 2021
- Pewaukee, WI
- 2015 PIU
Greetings all,
I have noises coming from the front driver side that sounds like bearings. I took it to my local mechanic and he said it is possible it is the PTU, but then hedged and said <15% chance of that, most likely just the bearing. He suggested taking it to a dealer. I've never done a bearing, but I've watched several utoob videos so I'm pretty close to an expert now
So here are a few questions:
1) Should I replace more than just the front driver side bearing if I'm doing them. Both fronts? I really hope nobody says all four...
2) Is the 2015 PTU similar to the 2014 PTU on the PIUs? I read through the forums and seen conflicting information which is why I'm asking to see if anyone who has a 2015 has done it and if there is a good guide or video I could follow.
I was going to replace the brake pads while I'm at it. Anything else I should consider doing?
