How to: - 2nd Gen Gauge Cluster Removal and LED Conversion V2 | Page 13 | Ford Explorer Forums
How to: 2nd Gen Gauge Cluster Removal and LED Conversion V2
I have a 97' XLT and I changed the gauges and heater controls out with some out of A 01 explorer sport and I put in my Red SMD LEDs and the heater controls look like crap (can hardly see them at night, and I only got a few bulbs working on the cluster and they don't light up. I'm really upset cause I have read all of the post saying how good they look and all. Could someone help me?
Did you remove the film on the back of the gauge face and heater controls? The Red light will not make it through the green film well at all...
The film on the sport gauges are like painted into the heater controls and won't come off easy. The 97xlt heater controls have a removable cover. The sport ones have one as well but it's clear and just cuts back some light so its not as strong.
I just said to hell with it and sent them back and I'm going to order some white ones.
Doing this right now putting it back together don't forget to put srews back in lol
194 from superbrightled.com
mine look like this as well. I used blue though. Soon enough i'll get the sport white face gauge cluster, and put my blue led's in that.
mine^^^
even though i do not have even lighting, i still do not miss the nasty off-white glow of the needles from the stock bulbs.
Guys i need help.. BAD!! I did this mod to my '01 XLT and everything went fine but the truck will not start. when i turn the key to run, the fuel pump and lights all go on like usual but when i go to the start position, it does nothing. It is not the battery. i think its something with the anti-theft. Pleaseee help me!!
Never mind got it fixed! just had to leave the key in accessory for awhile. :D the cluster looks amazing, this is the best modification yet to my Ex!
I'm with EXPLODRR, pics, or it didn't happen! :P
havent been on in a bit but heres mine the pic does it no good it a red like EXPLODRR's did it awile back just never got on to post it with every thing i had going on
Here is a image. they are a lot brighter in person, these damn cameras never work right!
Just a heads up, anyone who has the anti-theft alarm system with the engine immobilizer, unplug the battery and wait 15 minutes BEFORE you remove the cluster! and don't hook it back up until you are FOR SURE everything is put back together properly. The anti-theft on my '01 XLT activated the engine immobilizer because i left the battery hooked up. if this happens to you and the engine immobilizer will not let you start the vehicle (i.e. you turn the key on and everything works, fuel pump turns on, and all the lights but when you go to start it just does nothing) do these steps to lift the immobilizer
1. turn the key (with key fob on ring) to accessory (backwards) and let it stay in accessory for a minute or two.
2. turn the key to run (DO NOT TRY TO START) and let it sit in run for a minute or two. then the vehicle should start.
I could never get back into the Red dash lights after owning a pontiac haha. Both of those setups look great though! I'm still leaning towards replacing my gauges with the stock white face ones and putting some UV purple lights inside. We'll see how that goes, might be awhile yet.
Gauges won't work
Well, I finally got around to doing this. I just put in regular bulbs.
I turned the car on and the cluster was nice and bright. Unfortunately now none of the gauge needles will move (odometer, spedometer, etc), and nearly all of the other cluster warning lights won't light up (high beam and battery light will work, but none of the others will).
I thought I had hooked everything up correctly. Anyone have any thoughts? Is it possible that the cluster is getting power to the lights, but lacking something that would allow the gauges to move?
Thanks.
...Unfortunately now none of the gauge needles will move (odometer, spedometer, etc), and nearly all of the other cluster warning lights won't light up (high beam and battery light will work, but none of the others will)...
Thanks.
NOT sure but it sounds like you dont have a connector properly replaced. Hopefully someone knows which one, tho you may find it quicker to go back in yourself and check....
I have to go back in to see if there is a green film- on the 99xlt. and find out WHICH TOOL IT TAKES TO TAKE THE CLUSTER APART(??????????)
Mustang- which models have the green film? and how to you get to it?? special tool???????
Thanks:us::salute:
Does anyone know if this will work on a 91-94 Explorer? Or has anyone done this to a First Gen?
Thanks:us::salute:
I cant help you out with that one. I never took off the green film, and I don't believe there is any definite answer as to which models/years have the film.
It should work with any cluster, as long as you get the correct LEDs. I don't know if the 1st gen explorers use 194 bulbs in the cluster.
Well, it turns out that all of my gauge problems were due to a blown fuse. Number 11 blew and caused all the problems. Got it changed out and all the gauges and emergency indicator lights are now working. The new bulbs in the cluster look great too. Oh, and the radio backlighting also works now, too.
Thanks to everyone for your advice.
RE: DIAL removal
TOOK DASH APART AGAIN... a key bit of advise ****
if you plan on taking the dials off to take the gauge cluster sheets off- let the vehicle idle for 10-20 mins. Then, **TAKE A PIC OF THE DIAL LOCATIONS****. Use this as reference when putting back together before pushing the dials all the way on. ONCE you are done doing what have you, again, idle the vehicle for 10-20 mins then push dials all the way in.
