vanionBB
- March 31, 2006
- Kennewick, WA
- Explorer 1996 XLT
I added a secondary transmission filter from summit racing and now there is a high pitch whine sound. I think it is coming from the engine compartment, but I am not sure.
It only happens when the RPM's are at 2500 or higher, no matter what gear (though it does not seem to happen when it is standing still) It only seems to happen when the truck is under load.
1. I thought it was the belt, since I spilled some ATF on it, so I replaced this and it had no effect on the whine.
2. The tensioner seems to be working.
3. I double checked the in / out of the filter and it was installed correctly.
4. I removed the 2nd filter, but the sound is still there.
5. The sound seems to coincide with a loss of power at high rpm.
My guesses:
1. Something on the drive belt is going bad, ps pump maybe, or alternator. (I plan on removing the belt and driving it around the block to see if the sound goes away).
2. Cam shaft position sensor. I am not sure this would be effected by load conditions and I think this would make noise regardless of the rpm's.
Any help would be very much appreciated.
Best Regards
My guesses:
Best Regards
