MAS Tequila
- October 6, 2013
- Boca Raton FL
- 2015 PIU
In my case I did the keys without changing the shocks.
The ride quality improved, it wasn't as harsh when hitting uneven pavement or bumps. Just driving down the street seems more 'plush', it just feels better.
But then I did have to take turns out of the adjustment bolts to keep the lift at 2" to keep from putting the front axle joints in a bind.
After doing the rear springs and shackles the truck rides like new.
Right before putting the wheels and tires on I changed out the front shocks for the longer Ranchos, the ones I took off were only on the truck 6 months, just to be sure there would be no undue wear on the new tires.
There doesn't seem to be any noticeable difference in the ride quality between the different length shocks. But better safe than sorry.
The Monroe coilovers in the rear still required putting the floor jack under the bottom of the shock to get the bolts in. So I beleive that they are still long enough.
I firmly beleive that changing the spring rate by a TT will get you there, but stiffening the spring rate has to affect the quality of the ride, and put more stress on the t-bars. IT has to since the raise is gained by turning the adjustment bolts in further. Where with the keys I have fewer turns on the bolts resulting in a slightly softer spring rate than was started with.
MT
MT
I'd really like if more people chimed in here. I've seen this topic discussed in a few places and there are always people on both sides.
One thing I have noticed is that most people change out their shocks and/or shock brackets when getting new torsion keys. Comparing the ride quality of a torsion crank with regular shocks vs torsion keys and upgraded Rancho shocks and/or bracket isn't how you go about proving that a torsion key is better.
Has anyone done a torsion key and seen how it rides without the shock upgrade? Or other similar tests, such as torsion twist with ranchos, longer bolts with ranchos, etc...?
The reason I ask is because on this ranger forum, the conclusion is that the ride quality is ALL in the new shocks/bracket and has nothing really to do with the crank or keys.
http://www.therangerstation.com/forums/showthread.php?t=112249&page=2
I'm planning on getting a small lift soon and would like to hear more regarding this.
