97Sandbox
- February 7, 2019
- Seward, NE
- 2000 Explorer Sport
Looks like I'm going to try to rescue a Mounty this weekend. Here's a bit more info from the seller:
"this thing just sat for almost a year I guess. And then when I started it it had this problem with the smoking. When I take the oil cap off it would clear up so I put a new PCV valve in it and a new vacuum purge solenoid in it but that didn't fix it"
"I don't know if it helps any with trying to figure it out but it happened from sitting. It ran fine when we parked it but it's set for 8 or 9 months and then when I decided to sell it I started it up and it ran fine for about four or five miles and then it started doing that. I looked it up on the internet said PC valve or purge solenoid valve and I replaced both of those and it did nothing so I gave up"
The fact that it clears up with the oil filter cap off is definitely interesting. Do you all think the symptoms point to crankcase ventilation issues? If all it takes to bring it back is cleaning that screen and spraying seafoam in the vacuum lines, it'd be quite a deal.
EDIT: Wanted to add the seller said CEL is not on. I'll bring my scanner to check for pending codes nonetheless.
