holley has pros and cons, and right now i have a very sour taste with that system. that and once again if you are looking to do this on the cheep, a holley terminator x is out the window.
if you are leaving the motor stock, i would just use a stock pump. or better yet, if you are buying a donor truck, use its pump. its really all you need. if you are going to start modding it, then start to look for a aftermarket pump. (ive got a 347, 60lb injectors with a eaton m122 supercharger and i am still using a walbro 255 return style pump, but i am sure i am running on the edge with it).
All good points. I'm not sure SBF is really going to support my long-term goals, so I think you're right about keeping things stock and avoiding unnecessary costs in this swap/build for now.
a high volume pump is taller then a stock pump. i cant remember if its by a 1/4 or 1/2. which means you will also have clearance problems with the oil pan. normally you would dimple the pan and call it a day, however the oil pan for our motors is almost touching the rack. the motor i have in my truck right now was in member dono's truck. when he had this motor build, the builder had to notch the block, then machine the oil pump driveshaft to the correct length. you also have to keep in mind you dont want the sump to high or low in the pan because it will effect the suction as well.
Thanks for clarifying! That does sound like a pain and something best left to an expert (which I certainly am not). I'm surprised most of the replacement pumps on RockAuto are high volume and/or pressure -- they certainly don't imply the extra work to install.
when i did my swap, i ordered headers long before i was going to start. that way i was able to put them on the motor, before the motor went into the truck. way easier. i also swapped the explorer cam out for a stock foxbody cam. did it help, not sure. i did water pump, oil pump, timing chain and gears, all new gaskets, i gasket matched the upper intake to the lower intake, then the lower intake to the heads, and also did a clean up of any cast flash on the head ports. thats all i wanted at the time. didnt really think i was going to go much further then that. i think i even posted in my now novel of a thread saying something like i wont ever have a motor that make 400 plus horse power so i will be fine with the exhaust i have.......but here we are......
Yeah, I'm thinking it probably makes sense to go ahead and buy headers early so I have them when I'm ready. I'll have to keep an eye on whether anything comes of the new TMH contact or if I should just order OBXs.
I'd be curious to know if the Foxbody cam gained anything. I was reading
this article and was surprised in the first dyno test with a stock Explorer cam, their 302 made 294 hp and 328 lb-ft with basically just porting, bigger valve springs, and headers. Granted it was carbed in their test, so who really knows how representative it is for our application. What I'm getting at is it seems like the Ex cam isn't bad for torque.
Water pump, oil pump, and timing set all sound like smart choices to replace. Is the lower intake aluminum? I'd be interested to try my hand at gasket-match porting, but I'd be a little intimidated to grind on cast iron.
You're talking about your main "Evil" thread, right? I should add that to my list of light reading...
i could be very wrong about the cross member. i have never looked at a m5r2 close. i am going off what a 4r70 is. if you want a poly mount in that trans then yes, you are hacking up the cross member.
Worst case scenario, I modify mine like Nick26 showed. Best case scenario, it all works and I save some effort! I'll sort it out one way or another.
yep. a condenser for both 4L trucks bolt to the truck. the condenser for the 5L clips to the rad. why?
engineers/designers can be dicks. the condenser looks to be the same for both, they also both have the provisions for the mount tabs. you can leave it bolted to the truck, and place the 5L rad in and not know any different. ive had mine out a few times an never even think of it anymore.
Is the condenser really the same for both? Mounting tabs aside, I was reading
ahodges swap thread and got to the part where he was struggling with different fittings on AC lines and I think he ended up transplanting the whole setup from a 5.0 Mounty into his Ex. Maybe this was a 96/97 design change issue and if I stick to 2000 vehicles, I'll be okay with my stock condenser.
