97Sandbox
- February 7, 2019
- Seward, NE
- 2000 Explorer Sport
I read through an old 4x4 to 4x2 conversion thread and it doesn't quite capture what I'm thinking about.
Here's my situation: my ideal endgame is a '95-'97 Sport street truck with an LS3+T56 magnum swap (this thread is not meant as a place to talk about all the fab work that will be needed to pull that off -- hopefully that will come before too long though!).
To start, I had planned to find a relatively clean, running/driving, RWD OHV+M5OD truck and begin the build by upgrading the more straightforward systems like suspension and brakes and just keep up with engine and trans maintenance while I save up for the swap. The issue is that I'm seeing plenty of 4x4 models for sale, but virtually no RWD trucks. Conveniently, I have my '97 XLT -- SOHC+5R55E but more importantly RWD -- as a parts donor.
My question to you all is: if I have a RWD donor and I'm planning to build a RWD street truck, is it reasonable to start with a 4x4 Sport? My biggest concern is what to do with the transfer case after swapping out all the front suspension. I assume the 4x4 M5OD is shorter than a RWD equivalent, and I'd prefer to put off buying a trans for the truck until it's a Tremec with 6.2 liters bolted in front of it. Long term we're talking standalone ECU, but I'd also like to be able to drive the 4x4 turned 4x2 in semi-stock form and without too much issue in the interim.
What do you all think? Buy a 4x4 and start gutting my '97, or be patient and keep looking for a RWD sport? Thanks for your input!
