- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
The tensioners I am talking about are used for Polaris machines but compatible with our Ford SOHC engines (same cloyes body)
You see Polaris used the same Ford tensioner to tension the chains in the Prostar OHC engines.
I own three of these, a 2014, a 2015 and a 2018.
The 2014 and 2015 had timing chain rattle at cold start right from new
Installed manual tensioner(s) and the noise/problem is gone
The tensioners have come way down in price since I installed them
It is not solid, there is a stiff spring inside
There are several styles, Team Alba, Boondocker, Sparks Racing even some manual ones on Ebay:
$64 manual style
https://i.ebayimg.com/images/g/ZGsAAOSwlMFZJiaY/s-l1600.jpg
Boondocker "worm drive" style
Looks like the oil galley feed is plugged or at least bypass' this style tensioner
Timing chains are ALWAYS under tension with these, fool proof, Why would you ever want slack in your chains????
$64 manual style
