2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Excessive honing?
I don't know what your setup is for honing but the simple honing tool I have is only for removing the glaze on the walls to obtain a better ring seal. I use a ridge reamer to remove the ridge at the top of the cylinder that builds up due to the gap between the top of the compression ring and the deck surface. With 0.6mm overbore with a hone I would be concerned about bore taper, alignment and out-of-round tolerances.
