4'' lift Coil Spring lift | Ford Explorer Forums
yourmoma717
Norfolk, Virginia
92 SPORT
I just bought some new coil springs to give the front end of my x more tire clearance, well, what else do i have to buy/modify to make this lift work other than just putting in the springs?
If you don't have drop brackets "lift kit" then you'll need to get some before you can throw in 4" coils. If you don't, you'll never be able to align it. I'd also suggest a drop pitman arm so you're steering isn't too bad after the lift.
u can get all parts individually from suspensionconnection.com and its alot cheaper
will the ranger drop brackets fit my x? It is a 92, and I cant find anywhere to buy the drop brackets for my truck seperate from a lift kit
Did you try jcwhitney.com? I know theu used to sell the brackets.
no, they got the pitman arm, but not the drop brackets
alright, thanks
