WilliamWallaceGS
- August 22, 2012
- Hampton Roads, VA
- 1994 Ford Ranger
Hello all,
Hopefully some of you guys with experience with either of these cams will chime in, I did a search for this, but did not find my answer. How much does adding either a Comp Cams 410 or 422 grind cam on our 4.0s impact the idle behavior? The reason I ask is because I recently installed a 410 in mine, and after a few fiascos (I need to update my other thread with what I've done since) am just now able to drive the truck for an extended period of time, and my idle seems a bit goofy. I did the idle reset procedure, and she'll hover between 8-900 rpm when warmed up, she doesn't like much below that. Occasionally it will stumble under 800, and it will bog a little bit, but usually bounces right back. The idle is not as smooth as it was prior to the cam install, but I'm attributing that to the cam.
I've checked all of the normal things, fuel pressure, coil resistance test checked out OK (and I cleaned the coil ground plate/mounting bracket/other ground connections), new wires/plugs, IAC valve and TPS are new (TPS voltage is within spec), coolant temp. sensor and air temp sensor check out OK, MAF was cleaned, no codes. I've sprayed carb cleaner around checking for vacuum leaks and didn't find any. Any other time driving is butter, but just the funny idle.
This is the first vehicle I've owned with any sort of aftermarket cam, and I'm just wondering if this is just the nature of the beast, or if I have some other issues. I figured with the mild 410 that an idle change wouldn't be noticeable (so says Comp Cams), which is why I went 410 vs 422 since this is my DD. Thanks for any insights.
