- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Okay she’s running pretty well
This is on the old tune, made for the “old” engine
First run around the house real quick
Still running good, not going lean, all seems well
If you notice we solved a few exhaust leaks this time around with the improved remflex gaskets
I then let her heat soak after watching the thermostat open and checked all
Fluids… started and ran her again through a couple of heat cycles. She’s consistent which is good
Now for the bad news
The b&m rear differential cover has lost one of its hold down nuts…. No biggie right? Except now the stud turns on waaaaay too far… so I’m thinking the cap came off on the inside. So I am now pulling the rear cover and replacing the fluid. I cannot drive it around until this is solved for fear of the mia piece getting into the gears or locker.
Needed to change the diff fluid anyways, but wasn’t planning to do it like this
I picked up a timing light
The tuner and I on the phone were able to teach me how to check the timing and adjust it with the Holley if needed…. Timing sounds good to me, but will check with $34 harbor freight light
Next I just need to install the fan shroud and put some miles on it
Eddie coming to town at 2:30 am Sunday am (Amtrak only comes into Sandpoint late at night) plan is to drive her home Sunday
Old tune cost Eddie $1000 thus far… seems to be running okay with this new engine. She is smoooth and quiet, way more quiet then my sport trax
As always stay tuned
