- January 22, 2007
- selkirk, manitoba
- 98 supercharged 347 sport
congrats. i think the both of us have faced a few uphill battles over these last couple of years.
You are making me blush. I learned so much from your topic, so that my humble suggestion what our thoughts were installing WB02 mean nothing compared.Big SHOUT OUT to my buddy Tomazs Jankiewicz from Poland for the suggestions.
You see Tomazs is the ranger based vehicle expert of Poland, Tom and I are pen pals. He has built a wicked custom bronco ii (we are not worthy) using a v8 and Holley setup… he and his tuner were able to do similar with the wideband sensor… Tomazs is ahead of the game….. thanks man!!!
Welcome to the site.You are making me blush. I learned so much from your topic, so that my humble suggestion what our thoughts were installing WB02 mean nothing compared.
Generally speaking to explain for the rest of guys.
Holley wants you to put 02 sensor in one bank. Mostly because Term x does not offer any way of WB02 setup or configuration of the sensor, so when building the software that had to estimate some distance from the cylinder and calculate the reaction time.
But in Europe we do stuff a bit differently, and on my setup I decided to do stuff my way and I installed the sensor a bit downstream just after the down pipe merges into one pipe. Both for me and for couple very reputable guys I talked to, being able to monitor just one half of the engine was unthinkable.
Holley is not very common standalone in Europe. To be honest I have never heard of anyone using it, and for my tuner it was first time too.
And what his impression is? Term x max has very powerfull and fast hardware. It is very good in AFR management, compared to some real motorsport ECUs. So it handles placing WB02 further than expected very well. The only place where it may be lagging because of the O2 placement is low idle. On higher RPM exhaust gas travel so fast that extra foot means nothing. Just miliseconds. But after we tested and tuned it there were no issues with idle, or any part of the map. The downside of Holley ecu is it lacks in software advanced options. I guess they wanted to keep it simple.
About Bronco. I just suck in documenting stuff. I have a ton of pictures, but none of them show the truck as I would like to present it. After we will dyno it, we will have some professional photoshoot, and promo video done, and then I may find some courage to share it.
Btw I can't stop laughing how you spelled my first name. Polish language is apparently unpronouceable and unspellable for English speakers
Keep going.
Tomasz
Either the network interface card is only 10/100 or possibly the network cable.Very nice, very clean and ready to work.
The Wifi, I just found out my PC running on Ethernet is limited to 100mb/s speeds. My router is new and my TV gets 1200mb/s now, my old one was 800mb/s. I don't need much speed for my PC generally, but I didn't know that Ethernet was that slow. My PC test showed 93mb/s through the Xfinity website. The tech installed the router last week and said if I needed more for the PC, I'd have to install a Wifi card into it. Tech is not my thing, I pick it up very slowly.
Thanks. The Xfinity tech told me the Ethernet was limited that way. I guessed that he meant the cable itself, he ran the speed test so he explained it that way to me.Either the network interface card is only 10/100 or possibly the network cable.
It's possible to get 1000 mb/s over Ethernet but if the pc is doing everything you need it to I wouldn't worry about it.Thanks. The Xfinity tech told me the Ethernet was limited that way. I guessed that he meant the cable itself, he ran the speed test so he explained it that way to me.
