I am not sure? Maybe I can look into that when I get the suspension installed
Back at it folks.......schedule is cleared the hot part of summer is here, perfect time of year to moonlight in the shop = Time to focus on the 07!!!!!!
I spent half a day blowing the dust off the truck and collecting all the boxes of parts, then I started turning wrenches..........
The 2007 ranger no longer has a rear axle, it has been removed.
The front differential has also been dropped
The front 2007 Ranger dana 35 SLA differential and a 98 Explorer 31 spline 8.8 axle will be headed to town to be locked and geared.
Plan is 4.56 ring and pinion, ARB air locker for the rear
Next up it was time to install the new Brett built, High Plains Performance 4r70w transmission and new torque converter
with the trans on the trans jack I fill the converter with one quart of mercon V and stab it up, 3 clicks all the way back. The converter hub is also treated to a light film of assembly lube
Key to stabbing an auto trans is to get the correct angle from engine block to bellhousing
Then line up the converter studs with the holes in the flexplate. Make sure the scatter shield and alignment dowls are in their correct positions and then finally bring the trans to the engine using some bellhousing bolts
Line it up
start two bolts
check again
Now tighten BH bolts to bring trans flush with engine block
Stabbed and aligned
Now install converter nuts, 14mm, 4ea. 5.0 uses a 15/16" socket on the crank pulley to turn the engine around and gain access to converter studs. Engine rotates clockwise
The first converter nut will draw the converter forward 3/8", this is how you know you have stabbed a Ford RBV auto transmission correctly
Install remaining BH bolts
Install transmission dipstick tube and retainer bolt.
Now cleaning the transmission cooler lines in preparation for install
