- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
That's the first thing I thought too! and Brett lol
02?-07 all same sending unit
edit: wrong! I learned a few days later …If I search rockauto for a 05 and a 07 ranger fuel pump and sending unit they offer me the same part
Numbers) however the parts stores and ford clearly show them as different parts
I using a 05 cluster in a 07 truck with a 07 dash and 07 wiring harness. I ran a new wire, I tried a different ground, reversing polarity, checked continuity, ran my own leads to bypass harness...... same result. There is no anti slosh module on these its a microprocessor....it is kind of neat actually you can watch it take a "sample" about every minute....
55 ohm empty 230 full
I put 5 gallons of fresh fuel in it a few months ago when I started driving it, then during test drive on Wend i went to the fuel pump figured I would get as much fresh in there as I can...... I never could have foreseen this issue!
I am lucky I have:
05 ranger for parts
and a 04 mazda cluster in my hand already loose. I am headed to the truck this am...we are working on the suspension
Eddie can help me fix all this crap Saturday and Sunday
The good news is up to 70 mph no noises, no vibes, no shimmy no shakes.......the shifts are "positive' but not harsh....... Brett built a wicked good transmission here thus far, he has dialed in his 4r70w "recipe"
Im planning to put about 200 miles on it this weekend, I can film, Eddie can drive!
The 360 degree camera system is next.... oh joy! The instructions do not match the product and the wiring is not straight forward, its like a mish mash of parts and some things lost in translation. The way they have it setup the rear camera only gets power in reverse, that does not work for a 360 degree birdseye setup....... plus when you put in R it triggers the R camera, with the turn signals it triggers the screen to ajoining side camera.... that's all well and good except THEY ARE MISSING A POWER WIRE TO THE REAR CAMERA and the instructions show a different wiring harness altogether..only provide one trigger wire for the dvd player......more on this later
I am lucky I have:
05 ranger for parts
