The rear end has brakes!
Bit of a struggle to source and adapt all these parts but I got it done, bled, and tested by hand. I used M8 coupling nuts that I welded to the leaf brackets to emulate the factory soft line hold downs, I still need to come up with something for the hard lines.
Decided to go with a different style shock mount so I’m waiting on those to arrive. I’m going to run the stock length shocks for testing untill I get a good measurement and build a different cross member to hold the double eye style shock.
Tomorrow I’m going to double check torque on all the bolts and move it back and forth a few times with an empty dif. I don’t think it will hurt anything too much and those gears are getting replaced anyway.
Parts ordered for the front axle swap, and I just started cutting brackets off it today. Needs a full tear down. Once I know the rear works, and probably get the parking break working also, I’ll start the front end disassembly. Going to unbolt as much as possible, avoiding that point of no return that will inevitably come at some point and I have to cut all the brackets off the frame and probably modify the crossmember under the engine.
If anyone has any good insight as to setting up the propper angle with the leafs so I get the correct caster without shims, I’m all ears. Going shackles forward.
Oh and I made a 17ton shackle hitch because I got the shackle for free, so why not? lol
