5.5 superlift+ SOA..what next? | Page 2 | Ford Explorer Forums
How much are the Perry Fenders going to cost you? Also, do they paint them for you?
j602 said:
You don't need spacers/shackles AND perry's fenders. You could do one or the other and fit 35's.
Well everyone says i need gears 1st, before 35's,
Well we're trying to help you. :rolleyes: If you're going to move to 35's, then yes, gears should come first. Then you can do fenders or spacers/shackles, but both are not necessary.
alright
CodePoet said:
A trail rig needs to be as low as possible. If your going to go offroad...do not get a body lift, they add NOTHING except body roll, if you want to fit a bigger tire get a sazall and cut (it can still look good if you add some flares)
Agreed!! :thumbsup: :thumbsup: :thumbsup:
Jeff - :navajo:
thats a good Height i think, nice truck,
You dont need gears that bad, Right now i have 11 inchs of lift with 35's and 3.73 gears. Im in the process of regearing. As for four wheeling i have wheeled with alot of guys on this forum and body roll hasnt really an issue. 35's and 11 inchs is the perfect tire i think. Anything bugger would rub and anything smaller looks funny.
Jeff - :navajo:
That Najavo is Bad ASS! Keep up the good work!
This is 6" of lift with 36" tires (and they measure a true 36"). A little fender trimming is all that is needed, no F150 spacers and no expensive and fragile fibreglass fenders.
Does it rub at all when on the trail? I just worry about cutting tires up, that was my main concern.
No rubbing if you trim the fenders properly and adequately. You will also need to trim the plastic inner fenders.
Yay for searching!!!!!
FROADER said:
So you're going to go leafs then?
Yes, Whats the total amount for this conversion?
2-4 k?
Not sure, I would say somewhere around there. I got lucky with my second explorer, it was already done. :thumbsup:
Here is the link to the build up of mine written by Felix who I bought it from. Mine's got coils though.
Nice, i saw i think it was CHIEF'S old EB for 6k,. i would of bought that in a second, flydown everything.
thanks
