2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Before I spoke to James, I had purchased a 90mm LMAF, that has never left the box it came in....
He told me about an 80mm, from, if I remember right, '96-'02 4.6L Mustang GT or Cobra. It's still a 6 wire, with the integrated IAT sensor. I actually got one out of a V10 Triton equipped Econoline van ( thanks to the Hollander interchange) This is plug-and play, from a wire harness stand point, but obviously tuning will be required when I install it.
I received my Lightning 90mm MAF and as expected it has the 4 wire (no IAT) connector. I've decided to use my stock MAFsensor/IAT in the Lightning housing. I've started my design of a small (2x3x1 inch) adjustable gain linear amplifier that hopefully will make the 90mm (or any other housing diameter) combination look like a stock unit to the PCM. That way performance/fuel economy changes will be entirely a result of MAF and associated intake diameter changes. While a new "tune" would no doubt be very beneficial, it would introduce an additional set of variables.
I'll have to determine the stock MAF voltage output vs airflow. I can monitor the stock output voltage while changing the engine RPM but initially I won't be able to do the same with the 90mm. After stock voltage vs RPM is measured, testing will be done for each unit connected to a test power supply. The airflow will be provided by an electric duct fan (500 cfm) and a small electric 2 speed leaf blower. The three data points provided by the fan and blower should allow me to set the approximate gain of the amplifier for the 90mm. Then it should run well enough in the vehicle to measure output vs RPM and perform fine tuning.
All of the above is going to take a while but it has been many years since I've designed and built a printed circuit amplifier and I'm enjoying it thoroughly! One advantage of being retired is having a lot of spare time.
