myf16
- July 22, 2012
- northern California
- 96 Explorer XLT 4WD
Symptom: 4WD light illuminates, 4WD Low light does not. Flashing $WD and 4WD Low lights either 6 times or 4 time (it varies) on ignition turn-on.
I did the procedure described in the sticky: http://www.explorerforum.com/forums/showpost.php?p=1817539&postcount=1
Step 1) Jack up the front end OK
Step 2) Verify that the front driveshaft turns by hand. OK
Step 3) Start the vehicle and let it idle. Place your foot firmly on the brakes, place the transmission in NEUTRAL, engage 4low, then place the vehicle back in park. DO NOT ENGAGE ANY GEAR!! The lurch as the transmission engages could cause the vehicle to lurch and potentially fall off the jack stands.
**If the front driveshaft does not turn, the transfer case is locking properly and we need to continue searching. OK, except I had to engage Auto since 4low does not engage.
Step 4) With the front wheels in the air, engine idling in PARK, spin one front wheel.
If the front wheels do not spin in opposite directions, there is a problem with the front axle. This could be due to a mechanical problem with the diff, or a failure of the center axle disconnect to engage the passenger side axle shaft.
THIS APPEARS TO BE MY SITUATION, except that I couldn't get the 4WD Low light to turn on, so maybe the controller isn't commanding the front axle to lock.
What are my next steps?
The car is a 96 4WD with 105k miles and running pretty well in other respects. The previous owner reports never using the 4WD during the last several years. I am not positive that Auto is working correctly, but the above Step 3 indicates that it is.
Also, my local Ford dealer will diagnose this for $100. Is this case of sufficient difficulty to warrant that?
