96 Explorer 4.0 4wd - Fuel delivery problem | Ford Explorer Forums - Serious Explorations
RichardsMobile
Roanoke Virginia
96 Explorer XLT
97 F-150
I will first say I believe it is an electrical issue.
We have an intermittent fuel issue on our Explorer. It will run for weeks with no issues, then I will stop somewhere
and it will not start. I get it towed and it starts at the shop.
Sometimes it will run for an hour, then quit, sometimes 40 seconds, sometimes weeks.
Fuel pump replaced (Good quality)
Fuel Filter replaced.
Fuel line delivery tested.
Rubber lines replaced a couple of years ago.
Relays replaced and relay wiring confirmed good.
ECU connector cleaned and dialectic grease applied.
ECU connections looked good. No "burns" @ 1 year ago
Emergency cut-off switch tested - good
We (my current mechanic) put a meter on the power wire at the relay and sometimes it has power, sometimes not.
ECU Problem? I will replace the ECU anyway, having some 4WD issues that may stem from there.
Any ideas where the best place to get an ECU from?
Any ideas whatsoever?
imo get pcm from a JY its very far and few when they are bad, so unlikely youll get another bad one imo
Already done. Please see post.
Define ‘power wire at the relay’ as it can be interpreted in a few ways
OK, We refer to the same connector on the firewall....
I know of that "computer" in the firewall, is there another? My F150 has something behind the fuse box that controls 4WD and drivetrain...
OK. I need to purchase a PCM. Does anyone have a trusted source?
Very rare for a failed PCM . I'd try salvage yards.
Car-part dot com
Just be sure the year and engine are same, there is a 4 digit code on PCM make sure it also matches
JY id try first
Crack your PCM open, see if you can post pictures of both sides on circuit board
It's at the garage. I'll grab it tomorrow or Thursday.
Could this be crankshaft position sensor causing issues? Please let us know how this is,resolved.
allright Ill jump in here see if I can help
the ignition switch is turned to run or start, the EEC/PCM relay fires up and powers the computer
The PCM then controls the fuel pump with a ground signal to the fuel pump relay
It sounds like you are having an intermittent issue with the signal wire from the pcm to the fuel pump relay?
the battery power for the fuel pump goes through the fuel pump relay, then the inertia switch, then to the fuel pump
I assume you have changed the fuel pump relay (you said "changed relays") but you have also inspected the pins the relay plugs into?
Have you opened the bottom of the power junction box to inspect the wires? pins and connections?
You should also do a continuity test on the pcm to fuel pump relay signal wire (LB/OR), should be pin 80
Next would be to remove the pcm, open her up and have a look at the circuit boards/resistors/capacitors
