explorer savage
- July 26, 2014
- louisville ky
- 2005 explorer
Ive got a 97 explorer and took out the old trans and got one from a junkyard and in the bellhouse there are 2 shafts that lock into the torque converter on the one i took out the smaller center shaft goes into the outer shaft just past where the splines start on the one i got from the junkyard the center shaft sticks out past the splines about 3/4" and the torque converter doesnt lock in as far into the bellhousing is this because its a different model trans or is it because the flywheel and spacer on the other trans was different i didnt see what the trans came out of also is the center shaft supposed to be able to be pulled out
