00meangreenXLT
- December 4, 2010
- Green Brook, NJ
- 5.0 Exploder
I think I ended up with what you've got. That's was Dreddog recommended for me anyhow and he based that on your install.
I like the virtual "plug and play" aspect to doing this. The headlights don't seem to have much room to work with so getting some huge honkin' projector and cutting the headlights all the hell seemed like massive overkill to me and a real hassle. I like the compact nature of the MH1s and I'm told the performance is excellent. I already have several H1 HID capsules in reserve so I felt it was a no-brainer to go this route.
I don't really "mind" my current setup in the slightest. WAY better than stock and so much better than just slapping a HID kit in reflector housings. Talk about glare (been there, done that before I got my current lights). My headlights have seen better days. I screwed them up a bit during initial install, but otherwise they've held up quite well.
That's why I'll take my time doing the install. I scored some new "Diamond Cut" headlights and corners, in addition to the stuff from the group buy. I was going to get a new set of one piece projector lights before Dreddog put the idea in my head.
Thanks for the comments on the engine bay. Couldn't have done it without mod extraordinaire, "Turdle". He did it for me while I was down there in Kansas two summers ago. Also got the headers and a UI spacer installed while there too (and some upgraded hoot struts). Good times.
The "Explorer V8" badge I think was only available in '96. Sort of hard to come by. I've scored two via eBay in the past. I had my second one sent to Jon (Turdle) and obviously he weaved his magic with that too.
I may need to pick your brain once or twice to do the retrofit. How much time did it take you in total, from start to finish. Any general pointers? I'm hoping to do the deed before a long road trip planned at Christmas (Calgary->Milwaukee area and back). How do you like your setup? I went with 4300K (as I always do when I go HID). I did the "faux Philips" upgrade from TRS.
Cheers,
Brad
Yes the performance from the MH1 is very good for its size, and certainly a lot better than HIDs in the reflector housing (I've been there done that too as you can see in my avatar lol). I decided I wanted to go with them because when Dreddog was doing his original retrofit in his Bronco we put one of his MH1's in an extra stock Explorer housing that I had laying around to see how it would look/work and it fit in nice and snug and I really liked the way it looked. Here's a picture of that test fit:
Now, depending on which diamond headlight housing you have you may have to do a little dremeling (nothing major) so that the projector goes all the way in. I have the ones that had the shield that went over the halogen bulb, as seen here:
After you unscrew and take that shield off you're left with the little protrusion that the shield screwed into, which bumps the bowl of the projector and doesn't allow it to slide in flush with the back of the housing. It has to be dremeled away in order for the projector to fit all the way in.
Other than that, you may want to trim the projector shroud a little because while I got mine in without trimming it, I scratched the hell out of the chrome in the headlight housing on the top and bottom wiggling it in there
I did my retrofit over 2 days slowly (Dreddog wasn't around most of that weekend to help :roll
Getting the wiring harness for the HID kit to work properly was a whole different story though lol my high beams weren't working at first and it turned out that I had the 9007 connector from the kit pinned the wrong way and it blew a fuse that caused my high beams to not function (I don't remember which fuse number, maybe Dreddog will chime in if he remembers, we spent like 3 hours trying to make it work LOL).
But now that everything is in and working I am very happy with this setup, definetly a huge improvement over the halogen setup I was running before this, and an astronomical improvement over the pnp HID setup I had in the same housings the first few months i had the truck. The low beam is just awesome, and while the high beam on the MH1 isn't the greatest it is certainly a huge improvement from the halogen high beam (my pnp setup basically had no high beam so you can't even compare!).
Hopefully all this made sense, I'm pretty tired at the moment lol let me know if there's anything you need clarified
-John
And yeah those Explorer V8 badges were only on very early 96 V8 models, I've been wanting to get one but have yet to find one
