Murgatroy
- August 6, 2007
- Knoxvegas, Tennessee
- 2000 XLT
I recently picked up a `91 Explorer Sport. 2WD 5-Speed.
It has 111k on the ticker.
It has a few issues with it. Some might consider them major, I consider them minor. I am an experienced mechanic.
It currently has no brakes. The pedal requires pumping to get the vehicle to stop. I am going to do a complete brake makeover. Master cylinder, rear wheel cylinders, rotors, calipers, pads and shoes. Being as how I live in the south I don't think there should be rust effecting the brake hardlines. However if they do seem to be in bad shape I will replace them as well. I am aware that the problem might be solved by replacing fewer parts, but I figure I might as well do a thorough job once, instead of replacing many parts one at a time.
There is also an issue with an improperly installed throw out bearing. The transmission was recently replaced. It supposedly has a new clutch set in it. However the throw out bearing has a definite whine to it when the transmission in in neutral and the clutch is engaged. That is the only time it makes any noise. As this is a `91 model, I am correct in assuming that it has a separated slave cylinder and throw out bearing?
That ends the mechanical issues. The motor is strong, has no leaks and operates fine.
Next up is the interior. The Driver's seat is broken. The guy I purchased the truck from was a large guy, the seat is broken in the recline position. They are manual seats, no power to them. I am going to replace the seat itself with a junkyard donor.
Next are the doors. The interior is in pretty bad shape, nothing a lot of cleaning won't take care of, but the door panels are broken. The motors for the power windows have been removed. The windows still operate, you just have to manually slide them up and down. My solution is to replace the entire doors with donor parts from the junkyard. My question is, do Explorers come with manual crank windows? I am not a fan of power windows, however if I have to, I will swap back with those. The driver's door has some external damage, which is another reason to swap the doors themselves. Also, are the doors the same between the 2-door 4-door models? What about the Ranger? What options do I have to look for here, will only 2-door Explorer doors fit?
Finally are the gauges. From my initial observations, the fuel gauge and the tachometer don't work. Is this a common problem? Is it the cluster? Is it the sending units? Is the tach a mechanical tach or does it use an electronic speed sensor? If I am going to swap the gauge cluster, does it matter if I get a cluster from a 4x4 donor or an automatic? Other than the extra lights will there be any fitment issues?
That is about it as far as issues go. There are other things wrong with it to make it a great vehicle, the rear wiper arm is missing, the driver's fender is damaged, it has an exhaust leak and the stereo doesn't work. These however are minor problems that will be easy to fix. I am just curious about parts compatibility at this point.
Thank you for your help.
