1shot
- November 10, 2006
- Edmonton AB
- '92 XLT 2wd
Vehicle: 92 4.0 Auto 4x4 Exp
Okay on Easter Sunday I went out for a drive. Came home. Went back out to go for Easter Dinner at friends and the truck cranked over but wont start. I notice the absence of the old fuel pump hum.
- So i assume fuel system. - Got out the Haynes.
Followed the diagnose procedures.
Had voltage at pump connector at rear axle, so i knew it wasnt a fuse or Inertia switch therefore since the pump was very noisy before, I assumed it was the pump that failed.
Installed new Carter pump, connected everything back up - but no pump hum on start or run. I dry ran the pump prior to install so I knew it was good out of the box. So I confirmed by hotwiring it with 12v - yes pump is ok. It has a nice steady quiet hum compared to my old rattler.
So i double and triple checked all fuses in both locations.
Then I replaced all three relays under fuse panel. Checked and bypassed the Inertia switch.
Still no pump action.
So I get:
12.5V at battery and across all blades of fuses. I checked the relays and get either 0 or 12.5 volts depending on which relay blade and position of Ignition at that time.
I get 6.60 volts at bypass switch and I get 6.60 volts at connector at tank as well. When Pump is added to circuit the voltage drops to 0 and pump does not run. So Is the computer bagged or what? What voltage Am I supposed to see at the pump? I get 7.5 volts at the sending unit and 6.6 on the positive feed to the pump. My sending unit and gauge works properly as well. (tank is now back up to 1/4+ after Jerry canning it back up to make sure I wasnt drysuckin the pump)
Now my Haynes doesnt have anywhere near all of the electrical schematics a full ford book does, but I have seen a bunch that Shamaal has posted including the Autozone links and I am still confused.
I read somewhere in previous topics that the signal voltage is 6.6 volts, if that is the case which device creates this voltage? the relay or the computer? and if 6.6 volts is a good signal voltage, then why have I got 6.6 at my pump at the tank? Is not the voltage at the pump supposed to be 12V?
So I get:
