jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
Thanks for the replies. I don't have cruise control anyway so that's not an issue. I just don't want to throw a bunch of codes if the computer or wires aren't compatible with the swap. JD, thanks for the ecm part number, now I know what to look for. And switching to the Yam1 ecm sounds good, but I don't want to overcomplicate this swap or drag it out, if it requires more than just plugging it in. If the yam1 is plug and play then I'll take it since you're nearby and nobody else around here has a 94 manual 4.0 ecm.
O wait...you have a 94 explorer correct?? Its just auto?? Then yes the ecm would be YAM1...sorry...the 94 explorer is the only first gen that has sequential fire injectors, EGR and dual oxygen sensors..it should be plug and play, im about 90% sure...in my case it was a ranger ecm I was replacing with a 94 explorer 5speed ECM to gain sequential fire injection..what ecm code do you have now??
You wil have to use a 94 specific ecm as 94 explorer wiring for injectors are different. ..
