DecidedLife
- May 22, 2019
- 03 Ford Explorer E. Bauer
I have an 03 explorer eddie bauer edition and the compressor is not kicking on. I have jumpered from battery to coil, and know that the clutch works, compressor is in good shape. The system is full of refrigerant.
No power is coming to the compressor. I thought i may have damaged the wires at some point (ac had not worked for over a year), so i rewired from battery fuse box directly to compressor (using wiring diagrams, I assume I trapped into the correct wires).
I have tested and switched the relays, and i have checked all the fuses. The only fuse not coming on being #7 in passenger compartment, though the fuse is good.
I jumpered both cycling switches, but don't see any power coming to them with a test light with ac turned on and car running.
Next step is replacing the diode which I am picking up from the dealer today.
Any other items I'm overlooking? Is fuse 7 relevant at all?
