Stevo92z28
- November 21, 2006
- Springfield, VA
- '93 Eddie Bauer
Alright well my '93 EB came with fog lights but looks like aftermarket...using stock ford parts. Reason is the switch looks like a factory switch, factory ford fog light brackets. Bosch Fog lights with bosch relay, H3 bulbs. But looks like the front bumper is dremeled...and not factory type connectors ect. Well the problem is, they were working and now they are not.
First things first the fog light switch light was not lighting up. I investigated the 3 wires out of the switch. Power,Ground,Signal. Ok easy...ground wasnt secure re-grounded it and the light will come on. Next, i assume the power was somehow taped into the headlight switch so that it would ONLY come on with low beams i didnt like that. Cut the power and taped that into a 15 amp fuse at the box. Now turning on the switch...i hear the relay clicking under the engine bay. Looking at that it has the signal wire from the switch to it, then its own power/ground and then has the power/ground wires going to the fog lights. Tested voltage at the connectors by the fog lights....and no power.
Does this mean bad relay?
Next question...why do i need a relay if i want to control them without the required use of low beams?
If no relay i dont see why i just cant directly hook them up.
Last is this in the right section or should this be under performance lighting?
Thank you! Itd be nice to have fog lights again!
-Steve
-Steve
