Log sent to James. Tims pulley is creating detonation at part throttle when the trans is in overdrive. Not showing any boost, but I guess the SC is still pushing extra air in to the motor. A/F ratio is constant around 14.5 with the detonation happening.
I tried to compare iat's, but looking at the logs in excel, its pretty tough for me to compare against old logs. It does seem to be working though.
Heres a chunk under load:
RPM:4759 Load: 0.807 intake air:188 iat_sensor_temp:133 Spark_Advance:10.25 A/F Ratio:10.8
ambient is: "intake air:188" not sure I understand the number either
after supercharger: "iat_sensor_temp:133" again, a reference number
I thought a A/F ratio of 10.8 was pretty good for wot. Its 'safe'. Everything I can find on the internet says wot A/F of 12.5 for our older motors is where our motors are happiest. If anything, as the tuning gets closer, I'll probably try to convince James to get the wot A/F at atleast 12ish.
Id sure like to find some good reading on what all the pids mean, and 'how-to' basics on tuning.
When I did the log, it was about 23 Fahrenheit.
13.0 at wot sounds bad, I was told 11.2 or 11.5 the most when you lay into it. To give you guys an idea where I am at, seen 9.2 at first 1-2sec of pedal on the floor and then it goes up to 10.2, then 11.2-5. Never seen my lc1 report anything above 12, unless I am idling or just cruising. Don, what plugs did you switch to? I just picked up a set of tr06 plugs to check and see if I got any issues this weekend. I checked my notes and I am at .036 gap.
Phix, NGK tr7ix plugs. I don't think they work very well on our ohvs. I'm hearing quite a bit of detonation since install. I'm going to yank them.
Also, it seems James likes to keep wot a/f around 11 with forced induction. He must have his reasons. I'll have to read more.
Yes, I think James likes to go fairly rich on WOT in his tunes. I'm sure its a safety thing. Tim, my A/F sounds like its the same as yours at drive around/wot.
I sent James 3 logs. 1 while detonation was happening, 1 with a startup issue I have when the motor is warm, and 1 as a drive around. I explained that I think it might be the plugs causing part of the issue. This morning a new tune showed up in my in-box. I guess James wants to keep working with whats on my truck. I'm impressed.
More to come on tuning.
