- February 18, 2009
- Winnipeg, Manitoba
- 04 Mustang GT
Hey Phix, great to hear from you!
There has been no issue with my injectors, as the A/F ratio has always been fine. James has kept it good and rich to help with cooling.
Ron at RPCaster is going to give me a rough quote on a manifold with intercooler. I don't want him to go ahead and build it if the price is really high. I understand that a one off like this might be pretty expensive as its a lot of custom fabrication.
James is really concerned about the high iats, and doesn't want to do anything else with my motor unless I can get those temps down.
So, what does this mean? I'm going to go with larger pulleys. I might even have to go with the largest pulley (3.2"). I need to get the timing back. I was reading last night about pulling timing out, and efficiencies drop about 1% per degree pulled. This means, if timing was at 18 degrees, and is now at 7 degrees, Ive lost 11% efficiency while running high iat's. I need to get temps down, or quit trying to squeeze more power.
Phix, I think you are in the same boat as I am. We need to intercool to get rid of the heat soak issues we are seeing.
I'm running an e-fan, and ultimately that just increases under hood temps as its not running all the time.
