Another Oil Pressure Switch... Irritation.
4rd Xplora
On a Round Rock in Texas
2005 Eddie Bauer 2WD.
OK, narrowed down my oil pressure switch irratation. It only happens when I'm traveling down the interstate or somewhere when I hold a high speed for awhile and slow down and hit the brakes the needle will bounce to zero with a loud clicking noise and it may do it once or twice after I get into normal traffic. I think the alt. gage moves also but not as much. Don't think anything's wrong, more of a irratation than anything. Ever happen to anyone?
4rd Xplora
I said switch, I meant oil pressure gage.
4rd Xplora
Turdle, you've been right on, on all the advice you've given me in the past, so I'm on it. Thank you, sir. :dpchug:
D Do I need ANOTHER oil pressure sender again already ? Stock 1995 - 2001 Explorers 10
P Oil change, I know another one. Stock 1995 - 2001 Explorers 8
W Another rear differential oil ? Stock 1995 - 2001 Explorers 4
P Another Head Scratcher... Stock 1995 - 2001 Explorers 12
koda2000 Another chirping 5.0L cam synchronizer Stock 1995 - 2001 Explorers 10
M Another door lock issue. Stock 1995 - 2001 Explorers 6
H Another tire question. Stock 1995 - 2001 Explorers 1
Roont Another freebie: 99 with misfire Stock 1995 - 2001 Explorers 4
J Another 96 Exploder running rich with a twist Stock 1995 - 2001 Explorers 19
B Another intake gasket leak thread... Stock 1995 - 2001 Explorers 8
M Yet another OHV won't idle thread Stock 1995 - 2001 Explorers 4
H Another dumb bw4404 thread. Stock 1995 - 2001 Explorers 4
RustyMacintosh And Blue XLS makes 5-- bought another Exploder Stock 1995 - 2001 Explorers 11
M Our Explorer Was Totaled in Severe Accident, Need Advice About Buying Another One... Stock 1995 - 2001 Explorers 37
T Another Cranks but won't start thread Stock 1995 - 2001 Explorers 4
J XLT 98' no 4x4.... just another thead... Stock 1995 - 2001 Explorers 13
V Living the dream. Bought another EB. Stock 1995 - 2001 Explorers 5
L Another PATS problem Stock 1995 - 2001 Explorers 5
T Fix one thing. Get another problem... Stock 1995 - 2001 Explorers 17
prayforsurf0 Another Timing Chain Post Stock 1995 - 2001 Explorers 6
M Yet another "jack advice" thread Stock 1995 - 2001 Explorers 11
J Just another poor mileage tread.. Stock 1995 - 2001 Explorers 11
H "Not another tire size and type thread!" I'm sorry but plz hear and help me out. Stock 1995 - 2001 Explorers 5
E [98 Explorer XLT 5.0] (Another) Turn Signal Problem, Replaced Everything, Please Help Stock 1995 - 2001 Explorers 2
N 98 explorer rear hatch makes noise, doesn't lock plus another lock problem Stock 1995 - 2001 Explorers 1
B Another Battery Light Issue Stock 1995 - 2001 Explorers 2
A Another heat and ac thread Stock 1995 - 2001 Explorers 2
F Not another 4wd blinking question Stock 1995 - 2001 Explorers 1
W Fix 1 thing get another issue: Stalling Stock 1995 - 2001 Explorers 14
M And yet another cranks, no start question! Stock 1995 - 2001 Explorers 8
J Another misfire question Stock 1995 - 2001 Explorers 2
J Another Blower Motor Thread Stock 1995 - 2001 Explorers 19
B Another cranks, no start Stock 1995 - 2001 Explorers 2
T Bought another explorer few questions Stock 1995 - 2001 Explorers 1
C Another O/D problem? Stock 1995 - 2001 Explorers 2
J (Yet another) Plug question Stock 1995 - 2001 Explorers 33
M One Ex down, another in the works Stock 1995 - 2001 Explorers 2
D Another cruise control calamity Stock 1995 - 2001 Explorers 0
M Another O/D flashing thread Stock 1995 - 2001 Explorers 11
T LOL, another rough idle question... Oh boy Stock 1995 - 2001 Explorers 1
D Another brake thread. Stock 1995 - 2001 Explorers 9
3 another door lock problem Stock 1995 - 2001 Explorers 0
D Another 02 sensor removal problem Stock 1995 - 2001 Explorers 25
V Another A/C Problem Stock 1995 - 2001 Explorers 5
J yet another 4x4 question need advice Stock 1995 - 2001 Explorers 9
9 Another code 214 95 ex Stock 1995 - 2001 Explorers 0
W Another misfire thread 5.0L Stock 1995 - 2001 Explorers 0
O Yes, another stuck key thread!! Stock 1995 - 2001 Explorers 6
L Just got another Explorer (Has key-less entry issue) Stock 1995 - 2001 Explorers 5
E Another No Start Thread - SOLVED Stock 1995 - 2001 Explorers 2
Similar threads
